yeah ive had 3 people tell me its eletrical so im hoping...now the problem is trying to find out the eletrical problem lol
Need help!!!!!!!
Had the same issue and found a plug wire had a very small cut in it. When i found the bad wire you could see where it had been arching on a metal bracket. JMO
Try jiggling all your wires while the motor is running to find the one that is causing the problem . We just had a two day show and one of our buddies was having the same problem you are describing, didn't find it till the second day, it was the wiring too the pick up on the distributor(he had a crank trigger also), a zip tie was a bit too tight and had cut into the wire making it open intermittently .
