chevelle lower a question
  • Master X
    • 110
    I found a 69 cutlass at our local junk yard and was wondering if it has the same front lower control arms as a 69 chevelle? any help is appreciated.
  • z40chief
    • 90
    Yes, they are the same. May have round or oval bushings, still will bolt up.
    • Lizardracing
      • 839
      If it matters I never located a place to buy solid oval bushings. Round ones were easy to find. I learned from an old geezer that delron bushings are very effective and preventing the distortion found in stock rubber bushing but allow enough shock absorption to prevent pulling the frame mounts in a collision.
      • GUARDRAIL
        • 35
        Howe sells steel oval bushings
        • MM90
          • Oct 2010
          • 422
          Afco has both the round and oval shaped ligthweight steel bushings. I run poly bushings in my car for the same reason above about frame holes wearing.
