lift arm vs pullbar
  • juice87
    • 116
    lift arm vs pullbar
    whats everyones thoughts on lift arm vs pullbar on short 1/4 mile tracks with
    tight corners?
  • not clamped up
    • 287
    If you can't get to 36 '' out from the center of the quickchange to the 5th coil spring, don't waste your time they may run them shorter 5th arms with the usmts stuff The UMP tires takes a longer 5th arm.
    • erm11
      • 495
      You will also need to run a ton more lr bite.
      • not clamped up
        • 287
        erm is correct we are 150 to 175 pds of LR,with the driver,this could be a great post if guys and gals would spit out some good info,I can tell you just about every thing that we wern't able to get to work and what has worked on UMP tires.
        • 1Blacksheep
          • Mar 2009
          • 701
          Lift worked great in the tack and was fast, but as the track slicks off it isn't worth a S*** on Pierce cars ! JME
          • xxxmod
            • Jan 2012
            • 111
            Not running a lift arm but if I was the LR shock would be clamped in front of the axle.Some very fast cars do this.
            • Racer96m
              • 425
              On a short 1/4 Bull ring, I think you are gona be better off with the pull bar setup. On a Bigger momentum type track, I can see the advantages of the lift bar. Just depends where and how you run.
              Dave
              • hotrod4890
                • 120
                What kind of adjustments does everyone make with torque arm as the track gets real slick to still have drive in the car?
                • let-r-eat
                  • 2319
                  Either will work but a pullbar would probably have more options for that short bullring.
                  BUCKLE UP NOW, YA HEAR?
