Shocks and spring on a pierce
  • emodracer
    • May 2012
    • 101
    What are people running on their pierce cars and having the most success with. I have it set up 4bar/z link. Will be running on a 3/8 high banked track and is generally drying out during heat races. Nice smooth slick track. Buying new shocks and springs for this year and wanting to know whats the best.
  • RaceMentally
    • Nov 2013
    • 137
    700. 650200 200175Heavy tracks we run 175 in lr We also run shorter upper bar on the left rear and 2" longer rr upper and over 20* strapped.
    When it seems all eyes are on you when you're wearing a new pair of jeans you wonder why everyone thinks you look so darn good in them. When taking them off you notice the sticker still on the pant leg.
    • bob75
      • 2814
      springs sound good but can you explain to me your bar lengths and what they do , sounds like you are trying to index the left rear, and take out the indexing on the right rear, what bar lenghts do you run on the rear then , and is this a spring behind car or clamped up,
      • anissa5
        • Jul 2010
        • 79
        Also what angle do you run in the short left upper
        • BlackMagic
          • Oct 2013
          • 45
          Bob75, I agree that the shorter left top bar will increase rebound indexing into the spring, but i believe the longer right top link will increase compression indexing into the spring not decrease it.
          • anissa5
            • Jul 2010
            • 79
            Most pierce car with right rear z-linked have the spring on top of rearend
            • RaceMentally
              • Nov 2013
              • 137
              The short upper we do for indexing purposes yes. We also change the mounting location on spring behind. we generally run either 15*, 20*, or 25* inward to centerline of chassis with adjustable mount to compensate fo LU bar length changes. The rr I set up on cars we run more RU angle and control the hike. Generally it makes the car have a constant in motion bite and doesn't allow spring pressure of bar angle affect that tire(youre locking in the amount of drive you limit to this tire). RU 18-22 dry 22-26 tacky. We do not change hike on LU unless we change rf spring and if we change rf spring to a lighter rate we usually do every 100lbs 3/4" longer LU. But genrally like most do 45* is a happy medium or a 4'-4 3/4" drop.Put up some pics of you car underneath.
              • anissa5
                • Jul 2010
                • 79
                When you do soften the rf I am guessing that in the slick then you add 3/4 long upper bar do you take indexing out
                • RaceMentally
                  • Nov 2013
                  • 137
                  We have to soften the rf in order to transfer weight to the right side of the car and to free it up in the rear. We only do this because we've had to tighten the rear of the car up. For the length change we usually relocate closer towards the axle tube on a multi hole bird cage. When we move the lr slider inward we do this to keep a certain load on spring during hike without changing percentages unloaded. On another note how many laps do you all believe you can run in the dry before you start slowing? We've tested most tires and the results are pretty astonishing. For example we found our 3000 lb sportsman pro stocks with 3 link suspension can run identical times that of a 4 bar modified at 2400-2450 on the same tire and also fall off time wise the same time. Now I will say none of our modifieds weigh less than 2600 lbs...
                  • BlackMagic
                    • Oct 2013
                    • 45
                    Can you Explain to me how softening the rf spring transfers more weight and frees your car up? To me this sounds physically impossible? Here is my thoughts on that.... Yes putting a softer spring in the right front will make the car "dive more" on that corner, but that does not mean it is transferring more weight.... If you're wanting to physically transfer more weight to the rf corner you would need to install a heavier rate spring. A stiffer rf spring is going to free you up on entry and tighten your exit not a softer spring.... Here is my reasoning on that matter... As you enter the corner weight is transferred from the rear of the car to the front, and from the left side to the right... Keep in mind the stiffer spring gets the weight.... So as we enter the corner with our now stiffer rf spring more weight is going to transfer off of the rr to the rf, and more weight from the LF to the rf than the LR to rr, than it would have with the previously softer rf spring. In doing this it leaves more weight on the LR corner making the car freer on entry and tighter off the corner. Let's go to the extreme on this and say you went with the softest rf spring ever "no spring at all" the car sure would roll over on the rf a lot..... But there would be no weight on that corner to drive the tire into the track right? I don't know everything but this is just my understanding of race car dynamics and my reasoning behind it, so feel free to correct me if I'm wrong and please explain to me how and why, knowledge is something I crave for!
                    • RaceMentally
                      • Nov 2013
                      • 137
                      So a lighter rf spring would not unload the lr more?
                      • BlackMagic
                        • Oct 2013
                        • 45
                        Explain to me why you think it does. In the majority of your posts you say you want to get discussions going and be open minded. This is me being open minded and seeking discussion. I provided more than enough information to explain my reasoning as to why I think you are wrong about weight transfer. Better yet it was more about why I think I am right. If I am in the wrong please explain to me how and why, so that I can further my knowledge and better my race program if it is me that is wrong here... I'm ready to learn please explain yourself
                        • RaceMentally
                          • Nov 2013
                          • 137
                          Do you see that there is more weight on the lr or less when placing a lighter spring into the rf?
                          • BlackMagic
                            • Oct 2013
                            • 45
                            I've already answered that question in my previous posts, but I'll break it down again in another way. If you're on the scales and you remove a #700 spring and replace it with a #600 on the rf and to not make any other adjustments it's going to de-wedge the car, therefore making the LR corner lighter. This will tighten entry off throttle and fee up exit handling.
                            • RaceMentally
                              • Nov 2013
                              • 137
                              so reducing lr bite will tighten entry?
