trans and ford 9 oils?
  • Duckhnter83
    • Apr 2013
    • 152
    What oil is everyone running in there sag/muncie 3 speeds? Any additives? And what's everyone running in there 9" rears? Any additives for the spools??
  • racincowboy3
    • Nov 2013
    • 32
    Run Amsoil severe gear lube in the rearend... nothing else...
    • Duckhnter83
      • Apr 2013
      • 152
      What weight 75-90? 75-110? 75-140? I assume no additives are needed for a spool?
      • racincowboy3
        • Nov 2013
        • 32
        No additives are needed. especially with that oil. I run the 90 in my cars and we even run it in sprint cars with great results
        • stockcar5
          • 1289
          dexron 6 in the trans and royal purple 75-90 in the rear end.
          • Duckhnter83
            • Apr 2013
            • 152
            Why dextron6 you would think auto trans fluid would just burn up the manual trans? I would think to use the same 75 -90 as the rear.
            • stockcar5
              • 1289
              nope, many manuals now come factory with some form of atf. I believe some aftermarket trannys also call for atf.
