Don't understand why you would be going to a wider housing either. To keep the rearend centered, the j-bar would need to be 1" longer. 60/2-2=28. 62/2-2=29
if you are wanting to keep the driveshaft running straight, use the same length j-bar. If you are trying to keep, for example, the right rear tire location you would run a 1" shorter one. Or a 1" longer one to keep the left rear tire location.
