leafspring car handling
  • frontrunner
    • Jan 2010
    • 195
    and what will the 93 do on lr compared to th 935 i have on lr?? and does the other shocks look alrgt???Thanks again for the help...
    • DaveBauerSS6
      • Jun 2010
      • 566
      The 3 being compression and 5 extension, going to a 3 extension the car will roll to the right faster and roll to the front faster. this will loosen the entry and the middle.
      The rear springs are too stiff. Put 150 across the rear, go to 40 bite to start.
      As derek said, a little rear steer will help some.
      Gator Engineering
      • Dirtrunner35
        • May 2010
        • 632
        If he is tight already wouldn't more right front weight make the car tighter ???
        • stock car driver
          • 3233
          How did your nova work out this year?
          • DaveBauerSS6
            • Jun 2010
            • 566
            Raced 6 times, won 2. Started mid year and only one IMCA Stock Car track in California limits my racing. Car has more potential, and the driver needs more seat time.
            Gator Engineering
            • DaveBauerSS6
              • Jun 2010
              • 566
              If you increase the RF spring rate, it will increase wedge during both lateral and rear to front weight transfer. This loosens the entry and tightens exit. Since he said the car was ok on the big track, I wouldn't do a spring change, but go to a softer extension shock on LR so the car sees the RF faster and to a very small degree more compression on that RF spring. It will loosen the entry and get the car rocked back on the LR faster. Leafs are pigs by design, typically over sprung and over shocked.
              Gator Engineering
              • frontrunner
                • Jan 2010
                • 195
                Thanks for the help guys....
                • frontrunner
                  • Jan 2010
                  • 195
                  Thanks.. And how much should i pull the rr back i have it back an 3/4 inch rgt now all the time...Thanks
                  • Dirtrunner35
                    • May 2010
                    • 632
                    [QUOTE=DaveBauerSS6;1751421]If you increase the RF spring rate, it will increase wedge during both lateral and rear to front weight transfer. This loosens the entry and tightens exit. Since he said the car was ok on the big track, I wouldn't do a spring change, but go to a softer extension shock on LR so the car sees the RF faster and to a very small degree more compression on that RF spring. It will loosen the entry and get the car rocked back on the LR faster. Leafs are pigs by design, typically over sprung and over shocked.[/QUR
                    Read this and tell me what you think. http://www.auto-ware.com/autoware-bi...mes;read=18963
                    • DaveBauerSS6
                      • Jun 2010
                      • 566
                      Good read.
                      Leafs cant be tuned as a bar car; a coil spring and short bars are mechanically different.
                      Agreed that more bite will loosen the entry; and increasing the RF spring rate will loosen the entry, in theory.
                      More LR extension keeps dynamic weight on the LR.
                      The fronts steer the car unless the rears are over driving them. This is based on assuming the front steering is correct, and the op said his car was good on the other track. In this case I think by changing the extension two things happen. Weight is reduced off the LR taking bite out, weight is increased on RF. The the benefit of increase in RF weight over comes the loss in bite and the car turns.
                      I have used this adjustment and it worked, maybe some other factors were involved and that contributed to it working. As it was discussed in the link, I think the shock mfgs and the experts differ on results due to the other variables.
                      As Jeff said on his setup, a lot of combos will work and it may take a different adjustment to fine tune it.
                      Try it if it doesn't work move on; if its good its a easy change between tracks.
                      Gator Engineering
                      • DaveBauerSS6
                        • Jun 2010
                        • 566
                        That's the most Ive ever ran. I run a minimum of 1/4 inch and wont go over 1/2 inch any more.
                        Gator Engineering
                        • Dirtrunner35
                          • May 2010
                          • 632
                          Good read.
                          So your saying reducing the extension or rebound on the lr takes weight off the tire ???
                          • DaveBauerSS6
                            • Jun 2010
                            • 566
                            Yes. Just like the motion examples on the scales that Canuck was using on that link. Now magnify the examples by the force of a 2500# car rolling into the corner. There is a compounding effect with more momentum. He uses the word momentary for the time of change because he is waiting on all 4 corners to relax on the scales.Correct for the example, but on track that change lasts as long as the force of the RF spring stops compressing.
                            Trying the best I can to answer.
                            Gator Engineering
                            • DaveBauerSS6
                              • Jun 2010
                              • 566
                              I was just wondering how a 3-9 shock would work on the LR.
                              Gator Engineering
                              • dirtrace09
                                • Aug 2007
                                • 746
                                I have tried all kinds of shocks on the rear of a leaf car. I have found that the less shock you give the left rear (like a 93) the more that leaf and corner likes it. However, keep in mind that to much or to little leaf spring rate can really throw a wrench in things.
