northern sportmod performance
  • 80racer
    • Jul 2011
    • 4
    Have to choose between a 602 crate motor, 6200 rpm 5.43 gear and an open motor, 7000 to 7500 rpm 6.00 to 6.50 gear which will produce the best performance ? I figure the cost is about the same because I have an open motor now that blew up. With the crate I would have to buy 4 barrel carb , different tranny coupler ect.
  • clbaker25x
    • Oct 2013
    • 85
    Crate is a no brainer for sportmods. Need to make sure you have the right setup where the chip kicks in softly.
    • 80racer
      • Jul 2011
      • 4
      Has anybody switched from an open motor to the crate motor ? Could you tell a difference, was your car faster with the crate motor ? Does the gearing affect the way the car handles ?
      • racinjj
        • 98
        I highly recommend the crate, I have driven both and use the crate in my car and recommend it to my customers. For the price you just cant beat it unless you build your own engines.
        www.UltimateRaceCars.com
        • 80racer
          • Jul 2011
          • 4
          I appreciate the responses. I do build my own motors , but I want the best performance. Switching to a 6.0 gear really felt like it improved acceleration. I know of one competitor who turns about 7500 rpm he won several races this year against mostly crates.
          • bentfender
            • Nov 2010
            • 21
            I have used both and won races and championships with both I like the built motor but I build my own. the crate is easy and runs good too
            • clbaker25x
              • Oct 2013
              • 85
              I have heard of guys being able to turn around 6800 RPM with a crate against the chip. When you add in a 4 barrell that is pretty tough to beat with an open motor.
              • 80racer
                • Jul 2011
                • 4
                I had not considered that the crate could turn more than 6200 rpm.
