Rear Bars
  • LateModel B23
    • Oct 2012
    • 283
    Rear Bars
    Outpace greaseable ??? Chromemoly tube and chromemoly rod ends ??? Just the usual steel tube and rod end ?? What is everyones preference/favorite ??
  • RaceMentally
    • Nov 2013
    • 137
    Swedge tubes work but do not hold up under an impact well. Anyone running a swedge tube on the top link is crazy as I see them break all the time. Chromoly is fine but dom is fine too. Swege tubes are only 1" od and then taper to the 5/8" threads. Weak design in my opinion and it shows when in a wreck. As for strength as well an aluminum arm is actually stronger on the 3/4" threaded stock hex shaped 1 1/4" od by a little over 10,000 lbs of shear force. We load tested them. However after a side impact they are weakened immensely. If anyone wants to argue its heavier and has more unsprung weight over 90% of the cars I have in my shop or see are guilty of other unprung weight items. As for rod ends. Find the best one that has been load tested that doesn't bind when it has a load. Example, at 2,000 lbs load we found a certain rod end that only has 90 inch lbs of resistance.
    When it seems all eyes are on you when you're wearing a new pair of jeans you wonder why everyone thinks you look so darn good in them. When taking them off you notice the sticker still on the pant leg.
    • Confused?
      • Apr 2009
      • 418
      I build my left side bars from CrMo and use swedge tubes on the right. I also build my pull bar tubes. One is CrMo and the other is DOM. Either way, they are TIG welded.
      • hammond motorsports
        • 269
        I build trailing arms 2 ways . 1- for the 5/8 rod end I use a 7/8 DOM tube and tap it for the 5/8 .Them machine wrench flats on the tube so you can tighten it and hold the tube with a 13/16 . 2- tube I build but cost more to do is a 1 1/8 Chrome Moly and then tig weld a bung in the end of the tube . It does remove a lot of weight .The only place I run a swedge tube is on the lf tie rod only .
        http://www.facebook.com/pages/Hammon...26044754164488
