I'm hoping someone here has some knowledge on the older dirt works cars. I have a DW7 and was wanting to know where to measure from to get the wheelbase? I have read conflicting answers. Do I measure from the lower grease zerk on the A arms to centerline of rear axle?
Wheelbase measurment
I plan to give Hoffman a call Monday. Just was seeing if anyone here had any advice. If I measured from the mid plate how would I know if my wheelbase would be 108" or not?
its hard to measure from the ball joints because most chassis's have the front snout welded on at an angle....l drop plumb bobs from the car in 6 spots and use a string / nails on a long 2x4 under the motor plate to check our Harris after a hit.... hang 2 down from the motor plate to the string, 2 over the rear end housing, and 2 down from the lower a arms....The Harris comes from them with the front clip turned 3/8" so taking that into account, will tell you what is happening on the front.... the most important one to me is the measurement from the string ( which is the mid plate) to the rear end... this tells me the truth about lead / trail on the rear end....... (static)
Then I can go back and measure the 4 bar lengths and know what is happening when I adjusts lengths at the track...." Most of my drivers have been new to 4 link stuff and I believe most of their chassis issues are really my driver issues....... "
see ya
johnny v
SCD, after reading all this, I've come to the conclusion that he is wanting to know where to measure for rear steer, I think.
Yes I'm trying to measure for rear steer and also to know if my rear end is square in the car also to meets the min/ max for Imca sport mod rules of 108min or 112 max. Also what would be the advantages of having a 112" wheelbase car as to 108"?
With the 72" rule from back of block (motor plate) to centerline of rear axle, the longer wheelbase will have a higher rear weight percentage.Originally posted by Duckhnter83 View PostYes I'm trying to measure for rear steer and also to know if my rear end is square in the car also to meets the min/ max for Imca sport mod rules of 108min or 112 max. Also what would be the advantages of having a 112" wheelbase car as to 108"?
IMO, you should run the shortest wheelbase you can. Car will turn quicker because all weight in the car is closer to the car's center of gravity and more weight transfer back-to-front, front-to-back.Originally posted by Duckhnter83 View PostYes I'm trying to measure for rear steer and also to know if my rear end is square in the car also to meets the min/ max for Imca sport mod rules of 108min or 112 max. Also what would be the advantages of having a 112" wheelbase car as to 108"?
Longer wheelbase might be easier to drive but won't be as fast as shorter wheelbase. Think of a Top Fuel dragster...the reason it's so long is because they don't WANT it to turn.Last edited by speedbuggy; 12-16-2013, 10:45 AM.
Actually that's not why they're so long... Ex: funny car.Originally posted by speedbuggy View PostIMO, you should run the shortest wheelbase you can. Car will turn quicker because all weight in the car is closer to the car's center of gravity and more weight transfer back-to-front, front-to-back. Longer wheelbase might be easier to drive but won't be as fast as shorter wheelbase. Think of a Top Fuel dragster...the reason it's so long is because they don't WANT it to turn.When it seems all eyes are on you when you're wearing a new pair of jeans you wonder why everyone thinks you look so darn good in them. When taking them off you notice the sticker still on the pant leg.
