I have a b mod chassis that was suppose to go the chassis builder to get checked, but I can't get a hold them. I need to start putting this car back together so I was wondering if there is a way to measure the front end to see if it's straight. I know this is a hail Mary, but any help would be appreciated. Thanks
Squareing Metric Stub
Without a jig you are going to struggle. No real accurate way in my opinionFind me on Facebook: Impetus Dirt Racing Technologies
Might get a few measurements off thisAttached Files2012 UMP Stock Car National Champions.
here is how i checked mine it might help you some start with a plung bob get car level start at mid plate mark a spot on the floor on each side of the plate were it bolts up . now go to front of car use bob come off the lower a arm ball joint grease insert mark a dot on the floor on both sides . then goto rear end and do the same off the front of rear end axle tubes now draw a line from dot to dot now measure and see if any thing is out should be the same from on both sides that how i square up my car hope this helps
