Running a longer bar some say will pull left front off of the ground. Not necessarily true. It depends on where the brackets are located on the chassis. You can run a 34" + bar and have it mounted on chassis at say a 24" bar length. The benefit is less angle change and slower reacting. Also, mounting in front of pinion a certain distance helps control bar angle during hike. There is no right or wrong answer to where to mount it but best advice is to have the most neutral car possible.
pull bar location
