J Bar chassis mount
  • imca37
    • Dec 2013
    • 13
    J Bar chassis mount
    What is the difference in location of where the j bar mounts to the pinion and the j bar mounts to the frame? Is the chassis mount supposed to be in line with the pinion mount/ J bar running parallel with the axel? Or is the chassis mount supposed to be ahead of the pinion? If ahead of the pinion, how much? Thanks
  • washeduptoo
    • 1353
    The chassis is usually ahead of the pinion, not sure exactly how much though. If its a 4link, the rear end will move forward as the rear end thrust. Best of luck.
    • Anonymous24
      • Jan 2014
      • 253
      Very good question! Usually the chassis mount is ahead of the pinion. You may need to use spacers to properly compensate bind issues during rear suspension lift and dive, including chassis roll. Easy way: lift car so all 4 wheels are at maximum travel. Measure J-bar angle. Set car on ground and have a few people stand on front and rear bumpers. Measure J-bar angle. Use spacers and bolts to adjust against binding. Also a good idea to round the bottom of the bolt head where bar mounts to pinion plate.This is my opinion. What works for one car may not work for another.
      Find me on Facebook: Impetus Dirt Racing Technologies
      • imca37
        • Dec 2013
        • 13
        Sounds good. I'm gonna make a spacer for the chassis mount to move it back a couple inches and see what happens
        • Anonymous24
          • Jan 2014
          • 253
          Be sure you make it out of some real durable material. The amount of load that bracket endures is massive. I have seen the chassis where to mount connects ripped completely away.
          • setup479point2
            • Feb 2013
            • 188
            Pretty sure if you do this you'll bend or rip the chassis mount out. I wouldn't do it . Better to rebuild the chassis mount , or if its a built chassis they have it where it needs to be already .
            • wisdirtfan
              • Oct 2013
              • 94
              You can weld another piece of 2 inch to the back of the existing mount on the chassis and use longer bolts on the clamp. I did this on our late model and it worked fine for the last 2 years didn't crack or rip at all and trust me the car got abused plenty lol.
              • imca37
                • Dec 2013
                • 13
                Yes if I were to space it that is exactly what I would do, weld another piece of 2x2 and use longer bolts. The real question is if I only knew what the optimal distance this mount had to be in front of the pinion I would be golden. Anybody know?
                • Confused?
                  • Apr 2009
                  • 418
                  About 2-1/2 inches, centerline to centerline of the heims with the frame mount being ahead of the pinion.
                  • setup479point2
                    • Feb 2013
                    • 188
                    If you do it this way it should work , you're rebuilding the chassis mount.
                    • imca37
                      • Dec 2013
                      • 13
                      2 1/2 inches. That's the answer I was looking for. Thanks and Welding a piece of 2x2 to the existing 2x2 should get me where I need to be. Thanks everyone
                      • Lizardracing
                        • Sep 2009
                        • 839
                        In my opinion the panhard bar should be parallel the the axle centerline when the axle is blocked up to simulate the attitude of the axle when in race conditions. This put the least amount of fore/aft loads on the pinion are as well as twisting on the chassis mount. 2.5" is likely a good rule of thumb however you should measure your car for accuracies.
