I just got an afco limiter cushion for lr....when setting the chain, say I want 5 inches of drop, do I set it at four or some other figure to allow for the "cushioning" effect or go ahead and set it at five.....if it compresses any or a lot, that would effect what i'm after as far as bar angles, etc..thanks for any input
chain limiter cushion
What are they using for a damper, a biscuit? If so it's probably not going to squish much more than a quarter inch.
What is the average amount of drop for a left rear? Going 4/4 and trying to get everything figured out.
Most people use 4-5 inches of drop. Some use more and some use less. Some set their drop to 45 degrees angle in lrt bar. Best of luck.
