When washing your car be sure not to use a chemical such as degreaser or any soaps around them. This causes pre nature failure of bushings due to drying them out. Washers are used between all bushing for life of the bushing and fine tuning. Be sure when liking for a pull bar you find one where the bushing doesn't slide over all thread. This causes pre mature wear of the bushings from the inside out and is actually designed this way unfortunately so you have to buy more sooner. Hope this helps you on your pull bar Flyin Iowan and any other questions please send a message. Thank you.
pull bar bushings
Another place to look for poly bushings is Right Foot, they have the biggest range of bushings that I have found.
Right foot performance explains bushings very well.Originally posted by MM90 View PostAnother place to look for poly bushings is Right Foot, they have the biggest range of bushings that I have found.http://www.rightfootperformance.net/...20Bushings.pdf
