K727 press in low friction
  • 3dracer
    • 421
    Does anyone know if it is possible to get a press in K727 low friction balljoint? QA1 says they can mix and match anything, but can't get me that.
  • RACERRAY
    • Feb 2010
    • 9
    Dosent Howe make anything that will work, they make a ton of different lengths and style of balljoints
    • LITE-INN
      • 12473
      UB Machine has been serving the racing industry for nearly 50 years!
      • 7uptruckracer
        Howe makes hybrid housings depending on what arm you are running you should be able to do it or you can also weld in the sleeve you want. We have an Impala with crown vic and Impala lowers that we welded the Chrysler sleeve in. Checkout Howe though they should have what you need.
        • speedbuggy
          • 259
          check out the Ultra - Low Friction Ball Joints at Lefthander chassis. you can get about anything you want.
          https://lefthanderchassis.com/v2a/pr...idcategory=331
