metric centerlink
  • cozmo28
    • Oct 2013
    • 42
    metric centerlink
    has anyone switched a pierce car over to the new improved centerlink from afco and did you have to change inner tie rod ends or outer heims ends
  • stock car driver
    • 3233
    Its not a new and improved from afco. Its a standard centerlink on a 1982-1992 Camaro, that afco found out some of us racers were using so they put them in their box and ran adds that apparently work.
    IMCA found out and made it illegal, thanks to afco and their need to re box and re name and try and sell parts to racers at more than they cost at the parts store.
    • cozmo28
      • Oct 2013
      • 42
      Originally posted by stock car driver View Post
      Its not a new and improved from afco. Its a standard centerlink on a 1982-1992 Camaro, that afco found out some of us racers were using so they put them in their box and ran adds that apparently work. IMCA found out and made it illegal, thanks to afco and their need to re box and re name and try and sell parts to racers at more than they cost at the parts store.
      this really don't answer my question
      • 48modracer
        • 266
        Yes, they work, you can buy one like Stockcar racer said. I ordered one for about $30-40 on rockauto. Switched to camaro inners at the same time to get better clearance on the frame.
        • cozmo28
          • Oct 2013
          • 42
          ok we already use 80 Camaro inner tie rod ends but and heims ends for outer tie rod ends but with this new center link my inner tie rods don't clear the frame
          • 48modracer
            • 266
            the cross member needs clearanced. You can take off the skid plate or grind it down. If you do not cut it off, then you need to take off at the idler arm or pittman arm to install tie rods. See picture here of a bandit car with it removed:
            • cozmo28
              • Oct 2013
              • 42
              ok thanx modracer
