Broke oil pump drive shaft????
  • 22mike
    • May 2008
    • 5
    Has anyone else had the top of the oil pump driveshaft shear off?? I was running about 7500rpms and suddenly lost all oil pressure. Pulled the motor down this morning to find it had sheared off. Oil pump is free, took pump apart no visible restriction, pulled the main caps and rod caps, no visible damage....
    Any ideas on cause?? Any help would be greatly appreciated..
  • setup479point2
    • Feb 2013
    • 188
    Would say a piece of something went through it , we broke the bottom of distributor off . If its not in the pump it may be somewhere else in there.
    • mattworx
      • May 2008
      • 109
      maybe this will help
      if your running a msd make sure your using a ARP oil pump shaft we found that the size of the gear on the msd has just enough extra clearance to brake off the ears on anything other then ARP shafts when turned above 7200 . don't use melling hv55 pumps there not made for racing anymore
      • stockcar5
        • 1289
        what kind of shaft was it? also what volume pump and what weight oil?
        • TeamLFR
          • Sep 2012
          • 6
          Check the gear on this distributor. We broke two shafts back to back. The slotted part on the gear was off centered slightly. Enough that you could see it.
          • leadfoot_35
            • Jun 2008
            • 509
            I've broke the shaft before as well. We use a msd distributor as well. We changed it to a chrome moly shaft and never had a problem again.
            Josh Smith #35
            • BWRC
              • Feb 2014
              • 9
              Mattworx is right, seen this a lot with the shaft that comes with melling pump, jmo install new 10555 melling pump with arp shaft.
