Front nose size
  • twisterf5
    • May 2012
    • 334
    Front nose size
    i am seeing a lot of cars with wide front body's and hoods. do you really need more down force on the front of a mod. i still run the same size 35'' from bumper to end of hood. just getting back into mods after 4 years off. but took fastest time at the track last sat and that with some late model there i just can't see why you need that much body up front. would love to hear your thoughts on this. is it just monkey see monkey do or is there at gain from it. thanks
  • thinkstomuch
    • Sep 2013
    • 231
    I can certainly see an advantage to keeping the front end down keeping the car turning good. But then you require the HP to counter that. My opinion is it is a good idea as long as you have the power. On the biggest tracks I can see this theory amplified. jmo
    • Fetters F5
      • Sep 2013
      • 15
      I think having a wide nose/hood also aids in drag. Instead of all that air hitting the firewall and going through the body, it redirects it around and over the body. As far as a noticeable gain, I doubt it's substantial.
      • Renegade Cust Susp
        • 349
        Had a guy tell me once the only thing that is free in racing is air. So why not use it the best you can?
        I think on big fast racetracks you will certainly feel a difference. On small or stop and go track I don't think there will be one at all. Cosmetically I think the long noses look cooler too lol.
        Broc Burton
        go.fast.crs@gmail.com
        • UltimateRaceCars
          • Jan 2014
          • 116
          Any air that hits the firewall is creating drag and not adding downforce, any air going through the dirty under side of the car is adding drag and not creating downforce. Seems pretty simple that any air that you can keep from going under will reduce drag and potentially add downforce. But like others said you probably wont see big gains but its definitely worth doing right and help yourself. I always try to take advantage of any gains I can with aero.
          www.UltimateRaceCars.com
          • twisterf5
            • May 2012
            • 334
            ok!! but if the air is going to hit the fire wall wouldn't the big hood hold it in. i would think with the small left side foot box open it would let the air out instead of trapping it. i can see some going over but with no fenders i am just thinking it is blocking it. most my tracks will be 3/8 or smaller. maybe i will pull some timed laps with both and see what works.
            • RaceMentally
              • Nov 2013
              • 137
              That bobble in turn 3 and 4 just cost you 4/10ths but the downforce depending on track maybe a tenth if lucky?.. Don't forget this isn't asphalt. The characteristic of the car or always different from set up and track. The air can be unpredictable as well. Head wind, tail, through corner side forces. If you ever want to fully understand aero grip go to an open wheel Indy car school on a windy day. Your braking points will vary immensely. But to conclude my thoughts focus on mechanical grip and make a cool body you like for looks and not so much aero grip.
              When it seems all eyes are on you when you're wearing a new pair of jeans you wonder why everyone thinks you look so darn good in them. When taking them off you notice the sticker still on the pant leg.
                • 349
                I know for a fact testing has been done and the cars are faster without hoods. That being said, less trapped air under the hood vs more exposed fire wall. There's a point at which an optimum balanced is reached. Pushing a 8x8 flat panel through the air that's mostly behind a LF tire and in turbulent air should produce less drag than a 55x50 hood with 5in tall sides would trap would it not?
                Broc Burton
                • twisterf5
                  • May 2012
                  • 334
                  it is just like our late models last year. a lot of big names having the sail panels cut out but this year they are back to almost solid. ran that myself but went back to solid because it lets more air out and not to the spoiler. after thinking about it i am just going to stay with the small nose and hood.
                  • qrteracer
                    • 159
                    Hell Twister I would put the easiest replacable nose if you are going to race Carolina......
                    • twisterf5
                      • May 2012
                      • 334
                      raced crate to long so i already have every thing bolt on 2 minutes and you can change whole body.
                      • js11
                        • Apr 2011
                        • 91
                        To the original question about the nose piece, I suppose it has a similar effect as a wing on a spring, etc, if you run the 1" lip, etc... i.e., down force on the front of the car.
                        As for the hood, my guess is that a hood will not do much (though maybe a little) to keep air off the driver-side firewall, since even if you do redirect noes from the nose, it will slip past the hood (since most folks aren't allowed to run the lip along the hood, sides) and you will still get the air rushing in at the out edges and through the motor compartment, etc. I could be wrong. But I think there is only marginal benefit on most dirt short tracks. I'm not even sure it looks better, and that's the important thing. LOL
                        Ultimately I think you can get more benefit with side force from the right side doors and extending that with the enclosed sail panels, since these cars do run with the rear kicked out quite a bit of the time.
                        • charcoal01
                          • 545
                          Any one seen what david reutamin (I'm sure I just spelled that wrong) with his hoods? I saw a video with him and he puts something on it that he calls the flamingo wing. He made a quick mention about redirecting air off the rf tire. Something else to think about I guess.
                          • powerslide
                            • 2696
                            This ugly thing that attaches to the side of the hood?
                            • qrteracer
                              • 159
                              I kinda like a guy who makes their car stand out and not like every other modified out there.......
                              Need to get out of the 70's and make the bodies like a 2014 modified !!
