car hopping down the track
  • cgs
    • Jan 2009
    • 91
    how about the spring at full drop not having any tension on it? spring has about half an inch play. run a 200 pound spring. just looking at all aspecs of what i have going on.
    • oldtrackchamp4x
      • 270
      My car is setup where it has tension at full drop so i can't say, maybe set your car up so it has a couple turns tension on spring and see what it does. JMO
      • JustAddDirt
        • 1893
        chain RR down so weight does not lift off spring.
        also take some of your lower bar angle out of it, witch will tighten entry a bit, but just try it.
        • mod71m
          • 393
          Are you running any sort of cushioning device on your LR chain or is it a solid chain? If you do take that off and try a solid chain on the LR.
          • cgs
            • Jan 2009
            • 91
            thanks just add dirt. ill try that.
            • cgs
              • Jan 2009
              • 91
              no cushioning device on the chain. im going to make shure both springs stay compressed and see what happens.
              • cgs
                • Jan 2009
                • 91
                Well practice is rained out, hopefully next weekend ill be able to try a few of the things that you all have recommended!!!
