hanging weight
  • redracersmod
    • Jun 2013
    • 45
    hanging weight
    Can you hang two 50 lb valve cover lead weights horizontaly off the grade 8 studs on the aluminum weight clamps or is it to much and the studs break off?
  • TCmod
    • Aug 2008
    • 94
    Ive hung 75lbs off 2 weight clamps before but they were vertical.. Should be fine.
    • stock car driver
      • 3233
      I wouldn't. I would buy some steel clamps. Why save weight on clamps to mount lead?
      • redracersmod
        • Jun 2013
        • 45
        The only reason I'm using them is because they were with the car when I bought it. Otherwise I would agree with you completely. I mounted the weights so the studs stuck out horizontally just because where I needed my weight was the only way to get it in there. This is all new to me so thanks for the help guys.
        • stock car driver
          • 3233
          are they welded on? buy some steel ones and remove the alum
          • 72Dubya
            • Sep 2011
            • 504
            I would definitely use steel. I do use aluminum weight mounts, but only for lead that is less than 25 pounds. Everything else is steel. Too afraid of the threads stripping on aluminum to go with any more weight. Have had that problem before... not enough surface for the clamp bolts.
            #72W U.M.P Stock Car
            • LM14
              • 490
              Some places won't let you use studs to mount weights and limit you to 50# per bracket for a reason. That's to much weight for 1 mounting point and a stud is the worst way to mount weight. Use steel brackets, grade 8 bolts and 1 weight per 2 brackets or weights on opposite side of the brackets with 4 bolts total. Horizontal would be the weakest way to mount the weights.
              Rough track, 100# hanging on a couple pieces of threaded rod is a disaster waiting to happen. Ever seen anyone hit with a weight off the track?
              SPark
              • redracersmod
                • Jun 2013
                • 45
                They are hanging on two clamps one on each end.
                • charcoal01
                  • 545
                  Something my grandfather told me a long time ago: if you have to ask if something is safe to do, you've already answered your own question. Use steel if it's more than 30 pounds and use two clamps. Also, think about the bar you're mounting 100 pounds of weight on. How thick or strong do you think that bar is?
                  • 7uptruckracer
                    We ended up with a legends car driver in a helicopter headed to the trauma hospital after a piece of tungsten came unfastned from a stud, spun his car and hit the driver behind him and knocked him out and hit Brian full speed in the door and broke his femur, better safe then sorry
                    • redracersmod
                      • Jun 2013
                      • 45
                      That's why I was asking is to be safe I don't want to hurt myself or anyone else. I don't know how much weight one of the clamps by them self can hold. So I assume I would be safe with 50lbs per clamp?
                      • stock car driver
                        • 3233
                        Some of the alum clamps cant hold a body strap. If you tighten a bolt in a allstar brand alum clamp till it bottoms out it will break right in half instantly...
                        I use alum here and there for temporary body mounts etc.. I would never hang 50 lbs on alum clamps.
                        I suppose you also used all thread?? not hardened grade 5 or 8 rod?
                        • zeroracing
                          • 1014
                          I have most of my weights in 25 lb blocks that are all the same, we use two aluminum clamps per block with this arrangement, I would not put much bigger on aluminum clamps, even on steel i think 25 lbs per clamp would be absolute max, the risk of failure and consequences to said failure are too much to go around overloading the clamps.
                          • redracersmod
                            • Jun 2013
                            • 45
                            I used grade 8 threaded rod. Where do you buy the steal weight clamps?
                            • stock car driver
                              • 3233
                              http://www.ebay.com/itm/Steel-Ballas...029b36&vxp=mtr
                              heres the first one I found on ebay
                              here is a place that popped in my head
                              UB Machine has been serving the racing industry for nearly 50 years!
