What is the optimal wear pattern for Hoosier g60s? If the car is set up right is feathering normal? I have equal temps side to side and I am feathering the tires on the rear and slightly on both fronts on a dry slick.
tire wear
Was told long time ago, if you are getting feathering you are back steering to much and sliding the car. JMO
um your turning left the tires are going to feather its a non issue. use temps to check your balance and set up not feathering
Usually feathers when you are sliding the car. Happens a lot to drivers who carry too much speed into the corner and slide through entry and middle. RF will feather a lot when the car is too tight and pushing the front end up the track middle out. It could be a traction issue but make sure you're not over shooting the corner first.
I have two possible answers for you. Your front suspension and steering componets may be set incorrectly. The scrub radius may be to excessive due to extreme toe change while having the wheels turned to the left or right. Measure your toe with wheels straight. Turn the wheels 30° to the left and remeasure your toe. Turn the wheel 30° to the right and again measure the toe. Its optimal to have as little toe change as possible with the wheels turned to the left or right. Different steering components may be required to achieve proper changes in scrub radius.Another possible scenario is that during chassis roll in dynamic, the sprung weight is over shooting the middle of the tire contact patch. This can cause the tire side wall to flex more than you would want it to, momentarily allowing the tire contact patch to slide upon the track surface causing light feathering. Personally, I believe it is more likely a steering components issue causing excessive tire scrub radius.Find me on Facebook: Impetus Dirt Racing Technologies
