UMP Motor?
  • RJ16
    • Oct 2011
    • 12
    UMP Motor?
    Greetings,
    I’m sure this has been discussed a number of times, but my track just started to allow UMP motors and was wondering what kind of motor combination I should look into building to be competitive. Will a Dart SHP block be sufficient? Should I go with a 23deg. 18deg. or 13deg cylinder head? Gas or alcohol? Any other advice would be greatly appreciated.
    Thanks, RJ
  • jsf74
    • 544
    650 horse with a smooth power band will get it done "most" places.
    • Anonymous24
      • Jan 2014
      • 253
      650hp sounds like a good starting point. Once your able to effectively hook that up, jump up in HP would be okay but not really needed unless your running large fast tracks such as Eldora for example.
      Find me on Facebook: Impetus Dirt Racing Technologies
      • JustAddDirt
        • 1893
        4.125 bore
        3 5/8 stroke crank
        6 inch rod.
        14:1 compression
        or
        4.125 bore
        3 7/8 stroke
        6 rod
        14:1 compression
        you will get so many different opinions on here about engines. The 2 I have are stated above.
        one is an 18º the other is 23º.
        one has more power than the other, but both are very competitive everywhere I have went with them.
        • JR. MECHANIC
          • 253
          ^^^^ 388 and 414 to help you guys out.
          Bore x bore x stroke x .7854 x number of cylinders = cubic inch
          • RJ16
            • Oct 2011
            • 12
            Thanks for all the help. What is the thoughts on gas vs alcohol?
            • jsf74
              • 544
              Gas
              Less percentage change.
              • JustAddDirt
                • 1893
                on the fence on fuel.
                alky will net you more torque, and horsepower, no overheating worries, just run a 180º thermostat, so motor will be up to temp before you run it, (less likely to flood oil with alky.)
                price of alky is cheaper, even if you double the usage to gas (which it is like 1.5 :1 for me) it is still cheaper.
                if you run a lot of long races... say 50 laps Gas me be the way to go
                less rear % drop, but not that significant, for a 20-25 lap feature.
                • Lizardracing
                  • 839
                  Gas ranges from 6-12/gallon and if you figure in the specific alky/gas parts as part of the cost my math says Alky is a little more work but a little less expensive overall.
