a little help with tight in loose off
  • redracersmod
    • Jun 2013
    • 45
    My car is tight getting in and loose off. Its a 3 link northern sport mod. Scale numbers lf 535 rf 489 lr677 rr 646 56.3 rear 51.6 left 31lbs lr bite Shocks are 3/5 rf 5/3 lf 5/3 lr 4 RRBar angles are 20° lr 2°rr Springs are rf 650 lf 600 rr175 lr200Any help would be great!
  • jsf74
    • 544
    More stagger or trail rr 1/4 inch. Improve entry and exit will be better.
    • Duckhnter83
      • Apr 2013
      • 152
      Would raising the right rear bar some help?
      • LM14
        • 490
        Add LR bite.
        SPark
        • stock car driver
          • 3233
          Need to know if tight in ON or OFF the gas. Completely opposite adjustments.
          • Duckhnter83
            • Apr 2013
            • 152
            What adjustment would you make for off throttle and what adjustment for on throttle?? I think the left rear going negative would be a problem also lack of lr bite
            • mudeater18
              • 1599
              Originally posted by LM14 View Post
              Add LR bite.
              SPark
              ^^^This^^^
              • redracersmod
                • Jun 2013
                • 45
                I'll try adding more lr bite. But now that its mentioned is my angle OK on the RR bar would that cause it to go negative and have problems? When should a guy look at a RR bar adjustment?
                • stock car driver
                  • 3233
                  off the gas tight I would add bite. 20 makes a big difference on my car or raise some ballast if you have it higher and left.
                  • clbaker25x
                    • Oct 2013
                    • 85
                    More bite is what I would do. I would add at least 100 pounds of bite.
                    • Duckhnter83
                      • Apr 2013
                      • 152
                      The car is tight and pushes on throttle
                      • clbaker25x
                        • Oct 2013
                        • 85
                        2 link
                        Sounds like a softer right front could help fix your issue. What stub are you on? Also raising your right side bar a hole or two will assist with loosening the car throughout the corner, but especially on entry.
                        • Duckhnter83
                          • Apr 2013
                          • 152
                          I kinda thread jacked but I am experiencing the same sorry redracer but hope the info tossed around here helped you as well.
                          • Duckhnter83
                            • Apr 2013
                            • 152
                            I'm on a chevelle stub
                            • clbaker25x
                              • Oct 2013
                              • 85
                              On a chevelle stub I would not run stiffer than 550 on RF. Go softer from there to free entry/middle. There is a huge fallacy that you need a big RF spring to help a 2 link get off the corner. Weight on the left rear tire is what gets a 2 link car off the corner. You don't need a big RF spring to do that. Once you get soft enough you will see the shaw and other setup stuff that says to stiffen right front to free car and soften to loosen. You are above the range will the car will effectively stay on the right front for long periods.If you don't want to soften the right front spring I would recommend putting a chunk of weight on your right front, or buying a crazy lock down shock for that corner. Too me both are severe crutch items that are junk, but you see guys doing it and being fairly fast with it. By crazy tie down I mean a 2 compression, 12 rebound valving or something in that range. Integra has some nice models that guys are using with valvings in that range.
