leaking RR hub seal
  • Duckhnter83
    • Apr 2013
    • 152
    leaking RR hub seal
    I have replaced the RR hub seal 2 times and its still leaking. Any way to get these things to seal up. I'm new to this. Someone told me a seal inside the third member could be the problem. Any help would be great!
  • LFMotorsports
    • Feb 2010
    • 247
    Several people make an axle tube seal that is driven into the tube inside by the 3rd member. If you don't have one at all, then install one soon. I have ran into the same issue on a 9" in an old car, but it had none. It will also help keep the oil near the gear, not down the tube. Might just save you from tearing up a gear.
    • Duckhnter83
      • Apr 2013
      • 152
      So you are saying that the seal inside the third member axle tube is probably letting to much oil down the tube??
      • LFMotorsports
        • Feb 2010
        • 247
        Yes, that would be my guess. Someone use to make a cheap foam type product to use but I have not looked for that in a while. If you don't have an inner tube seal, install one. That resolved all my issues. I found this when I first bought that car, in which a gear was junk and oil on the RR rotor. When I inspected inside the gear housing, found no seal. I put a seal in both sides (left and right). Had no issues.
        • Duckhnter83
          • Apr 2013
          • 152
          Does this still allow some oil down the tube to oil the bearing?
          • MM90
            • Oct 2010
            • 422
            I have an inner axle seal on both tubes of my rear end. I just installed outer axle seals that install into snout where the axle goes into. With this setup you have to pack the wheel bearings with grease because little to no diff fluid will lubricate the bearings.
            • clbaker25x
              • Oct 2013
              • 85
              Axle Seals
              That is what we do also. Have to grease the wheel bearings if you run innner axle seals. Good news is no oil on your brake rotors and mess everywhere.
              • LFMotorsports
                • Feb 2010
                • 247
                Grease wheel bearings as stated. Don't "over pack" the bearings so they don't run too hot but it's just like you front hubs. Hope this helps you out.
                • hughesracing9
                  • Nov 2007
                  • 127
                  and it allows you to pull an axle while scaling with no mess. inner seals all the way
                  • autoshop
                    • 58
                    way back in the day we used to steal the ole ladys tampons and use them in the tubes, but that was before they made inner seals....
