tight on entry
  • washeduptoo
    • 1353
    tight on entry
    Last week we went to a different track and with a different driver. Car was tight on entry and tight in the middle on the throttle. Going back to same track this week with the regular driver, going to change offset on rr from a 4 to a 3, hate to change much do to different driver. Front springs are 600 lf and 550rf and still have about 1in of shock rod left showing. Thanks
  • Dirtrunner35
    • May 2010
    • 632
    track real tacky ?
    • JustAddDirt
      • 1893
      raise j bar on rear end. that will loosen entry and middle
      • powerslide
        • 2696
        What else if the J-bar is already at the top on the pinion side?
        • HEAVY DUTY
          • 796
          If the j bar is all the way up, there is probably something else going on. It isn't normal for the j bar to be that high, which is what would make me think it was something else. Make sure it isn't a brake problem first. The compression being too soft on the LR shock is the main thing that causes a 4 bar car to be too tight on entry. ( new driver not trail braking or arcing in the same as the other driver letting the LR drop on entry)
          • powerslide
            • 2696
            I was just throwing that out to see what i got for answers, i know nothing of the OP car or setup. Even w/ the quickchange you guys are never at the top on the pinion?
            • Racer96m
              • 425
              Nope, never.
              Dave
              • powerslide
                • 2696
                I started with mine at the top on my q/c. It was about a inch above the pinion i believe(i will double check) which is in the bottom hole or pretty close on a 9in. Car was still usually tight on entry on hammer down bull ring. What are you guys doing to free the car up to compensate for the low panhard location? How much trail? front spring split? You guys run UMP tires so that may play into the balancing act as well.
                • jsf74
                  • 544
                  Dont lightning mods have the panhard bar mounted all the way up on the pinion mount?
                  • z40chief
                    • 90
                    Heavy Duty should know since he builds Lightnings.
                    • JustAddDirt
                      • 1893
                      jsf74
                      straight panhard bar mounts to top of pinion plate.
                      j bar is 1" above pinion centerline. Per Lightning set up sheet.
                      • washeduptoo
                        • 1353
                        Sorry I haven't answered back sooner as I had a brother-in-law having surgery yesterday and when I got home, I couldn't get on 4m. We are at center of pinion on qc and if the offset doesn't work, that would be a good adjustment. Thanks for the help.
                        • HEAVY DUTY
                          • 796
                          Using the term" top" on the pinion plate differs with which pinion plate you have. Some are 3" above pinion, while others are 1" above pinion. It is common for a J bar to be between 1 1/2" above to slightly below on a mod. A straight bar on the left side of the pinion is usually higher than the J bar would be.
                          • washeduptoo
                            • 1353
                            What about moving the lrt bar up past the 45degree angle to add more rear steer, lr is chained at 45 degrees right now. What about swapping front springs or putting a 600 in rf? What do y'all think of these adjustments? Thanks
                            • Flyin Iowan
                              • 558
                              What about more stagger?
                              Chris Zogg
