Heavier RF Spring Changes What on entry?
  • thinkstomuch
    • Sep 2013
    • 231
    I've heard some different opinions on this so I'd thought I'd ask for more:1. Heavier RF Spring wont let the car roll onto the RF keeping the rear steer out of it, making the car tight on entry.2. Heavier RF Spring loads the LR more when entering which will loosen the car on entry.So which one is right and why?Metric Clip, Clamped LR - Z Link RR
  • HEAVY DUTY
    • 796
    A heavier RF spring puts more weight on the RF when transferring weight rear to front, or left to right, which makes the RF tire stick harder and turn the car on entry and thru the middle. It also gives something for the LR to drive against when on the throttle. I would say that the roll steer is controlled more by the LR shock compression, and panhard bar rake. Although, if you are way too stiff on the RF, it would take roll out, and hold the car up off of the RR spring when the car is trying to roll, causing a loose/ skate. You have to run a lot stiffer spring on the front of a metric front end with metric lowers, just because of the leverage ratio of that control arm .
    • MiddleMan
      • Jul 2012
      • 24
      What's too stiff for Nova lowers or metric lowers
      650lb
      750lb
      850lb
      • thinkstomuch
        • Sep 2013
        • 231
        For nova I'm in the 600# - 700# range. Works for me sometimes, other times car is very tight
        • HEAVY DUTY
          • 796
          Different makes of cars are different on spring rates. Nova stuff usually are in the 650 to 800 range. Stock metric stuff 1000 or 1100
          • thinkstomuch
            • Sep 2013
            • 231
            So then I assume a softer LF would help the car turn on entry? Loading the RF more
            • Dirtrunner35
              • May 2010
              • 632
              If the car is tight because too much spring and you go with a heavier spring it will make it worse, ONLY if it's a spring problem and not a driver (entry) problem. If i go in wrong my car is tight.
              • jsf74
                • 544
                What would you be doing wrong on entry to make your car tight?
                • Brian Gray
                  • Feb 2012
                  • 1102
                  Driving in to hard = too tight. Hard on brakes or too much front bias = too tight . not enough front traction = too tight. Front Tires overloaded = too tight.
                  During weight transfer the heavier spring gets the weight.
                  Shocks by BGR army
                  • cozmo28
                    • Oct 2013
                    • 42
                    stiffer right front spring will loosen car on entry
                      • 14304
                      Typically, the stiffer RF loosens entry into the corner while coasting or using the correct amount of braking. This may not be the case if the original spring was already too stiff and shocking the tire contact patch. It may also not be true if the change is large enough to have a noticeable impact on the attitude of the chassis. It is simply not enough to be able to memorize what a change does and always get that result. We have to be able to read what the car is doing.
                      • thinkstomuch
                        • Sep 2013
                        • 231
                        Very strong point MasterSbilt - there are always two ways to skin a cat it seems. Pin pointing the exact cause holds the answer but the get to this is the difficult part for many
                        • Brian Gray
                          • Feb 2012
                          • 1102
                          After rereading your initial post both 1and 2 are wrong. The car doesn't work that way regardless of the suspension. Remember the race car only knows what is happening at the contact patches. "It doesn't care what springs shocks or suspension is on it. "Mark bush.
                          Shocks by BGR army
                          • Brian Gray
                            • Feb 2012
                            • 1102
                            I would Recommend before making any changes to springs etc. Work on keeping the tires hooked up. Focus on driving the car in a manner that will keep your tires from slipping and loosing traction. If this means slowing down do so. Then ask yourself what do I need the car to do? Then your process can start working through what changes will get the results that I need? I will tell you anytime you hear someone talk about cross weight and transfer from lr to rf or the other way around close your mind. It will mess up your process the car doesn't work like that.
                            Shocks by BGR army
                            • Anonymous24
                              • Jan 2014
                              • 253
                              If you do your homework, you can calculate what spring rate is required for each wheel. Spring rates are dictated by several factors: wheel rate, suspension type, spring frequency, sprung and unsprung weight, center of gravity height, front and rear roll centers, the length of the moment arm, and the total amount of weight that needs to be transferred. Proper weight transfer is a must. Ex: RF wheel rate 950 (dynamic cornering) RR wheel rate 950 (dynamic cornering) changing spring rates on the car to fix handling issues is just a band aid when you should have stitches.
                              Find me on Facebook: Impetus Dirt Racing Technologies
