I have a 06 pierce clamp car. How long is he pullbar supposed to be?
Pull bar on Pierce
OK I should have rephrased it. My mount brackets are 20 1/2 inches apart. I can make the pull bar length 19 1/2 no problem. So should I mount it to the car and just adjust it down to 19 1/2 inches? I'm new to all of this so bare with me if you could.
Yes the length sets your pinion angle just put it to 19 1/2 mount it on the chassis end and push your 90/10 bracket thats mount on the rear end forward until you can hook it up this will nose the pinion down as you push it forward it should set your angle to around 7* down and if its a pierce 90/10 bracket the bottom is angle cut to where when your pinion it right the angle cut will be level in reference to the ground.
