J-bar
  • el paso mod 19
    • May 2013
    • 65
    J-bar
    Why do most mount their j-bar 1 1/2 inch above pinion? What does it change as far as handling? Mine is mounted even with pinion just like on a 9 inch. If you mount it above pinion and set frame mount at a height that will give you the same split as before on the 9 inch, say 5 inches, does my droop stay the same. I don't want to over-rotate the birdcages. Thanks
  • Confused?
    • Apr 2009
    • 418
    The higher the j-bar, the looser the car and less body roll.
    The pinion on a quick change is about 2" lower than one on a 9" That being said, if the j-bar was mounted center on a 9" and then a quick change was installed, with the j-bar mounted center again, it will be 2" lower. This will increase body roll and make the car much tighter
    • el paso mod 19
      • May 2013
      • 65
      OK, thanks Confused? My car is still on the loose side and I was trying to make sure that where my j-bar is mounted wasn't the problem.
