pull bar swedge tube length on an older Harris ( 07-08 over-rail 4 bar)
  • johnny v
    • Mar 2011
    • 197
    anyone have any idea what the last sentence in this Harris set up sheet on pull bar tubes means ?? never heard of " 4 inch rear end extensions ">>>>>>
    • 1 Way – Adjust ¾” nylcok jam nut until 1 15/16” of the treaded shaft is exposed.
    Preload spring ¼” by adjusting (3) 5/16” preload adjuster locking nuts that contact the
    front spring plate. The unit uses an 18” swedge tube.
    • 2 Stage – Aluminum adjuster nut for setting the travel on the inner biscuits need to be
    adjusted 3/8” from the back plate. Preload spring ¼” by adjusting (3) 5/16” preload
    adjuster locking nuts that contact the front spring plate. Progressive spring needs to be
    preloaded ¾”. This unit uses a 16” swedge tube.
    • 3 Stage – same as 2 stage. This unit uses a 14” swedge tube.
    • 2 Biscuit – preload 1/8” This unit uses a 16” swedge tube.
    • 3 Biscuit – preload 1/8” This unit uses a 14” swedge tube.
    • Spring recommendations – 1200lbs or progressive IMCA or without a spoiler. 1450
    for USMTS or with a spoiler.
    * Swedge tube lengths are for the 4” rear end extensions.
    see ya
    johnny v
  • stock car driver
    • 3233
    its a bolt on extension
