Just as the thread says. How can I get more forward drive out of my northern sport mod? I need to tighten exit just a little and get more drive off the corner. Thanks guys.
IMCA sport mod needs more forward drive.
Any one BUT Brian Gray. His quote "Most racers are scum bags" tells you all you need to know about him. He got a shock Dyno a month or so ago and now spends his time on 4M trying to sell shocks and services. List more information about your car and I am sure some guys on hear can help. Always ask guys you race with for help. Many will help you I am sure. While good shocks can help if you are missing in other areas it can also hurt your car.Originally posted by Duckhnter83 View PostWhat recommendations for shocks?
Is your entry good? If so, I would try adding 20-30 more pounds of bite. Adding more bite will typically loosen entry a little. Also i would try adding bite before buying shocks as adding bite doesn't cost anything! JMO.
Yes entry is good. I have 51.6 left 56.3 rear and 85lbs of bite. It enters decent. Shocks are qa1 3/5 rf 5/3 lf 5/3 lr and 4 rr
Are you looking to tighten exit or more traction? They are not the same. Do you want a big change or a little one?
Sorry. Should have said the extra bite will give you more drive off on top of loosening entry a little. As for tightening your exit "just a little" as you stated. Maybe a little more rear % or shorten r side wheel base 1/8 - 3/16 in. Only try one suggestion at a time so you know what works. JMO.
