Why would oil come out my rear end breather I have it routed up by the fuel tank and its pushing oil out. I put a gallon of oil in it. Anyone else have this problem or a cure?
oil out rear end breather.
9" or qc ? sounds like too much oil, qc level is supposed to be 2" below the c/line of axle in
Winter's book..." Most of my drivers have been new to 4 link stuff and I believe most of their chassis issues are really my driver issues....... "
see ya
johnny v
Its on the driver side on the case between the axle and the top. First time we changed the oil since we got the car ran it a few races and never had the issue until we changed oil. Although when we drained it we didn't get a gallon out of it maybe a little over 3 quarts so maybe with a gallon its enough to fling it up the tube. The tube runs up next to the fuel cell just below the deck.
Sounds like too much oil , i just used the stock hole on the side and filled i to the edge, never had a problem
If it has the inner axle seals 4qts may be too much, 3qts should be good.
Yes I did put an inner axle seal in the universal one from speedway because my hub seal kept leaking.
