rear panhard bar tech
  • redracersmod
    • Jun 2013
    • 45
    Ok guys I was talking with a fellow racer yesterday about panhard bars and adjustment he said he searched the forum and found lots of conflicting info on adjustment and was left with even more confusion. So maybe someone with more knowledge then I do can help make all of us more informed. Let's start by looking at what each adjustment does individually. What does it do (tighten or loosen and where) if you only raise the panhard bar on the frame? What if you lower it? What about if you only change it on pinion up or down? Lastly both together up or down. Thanks guys
  • let-r-eat
    • 2319
    More than 40 years ago, AFCO racing and performance parts first answered the simple need for better racing suspension. AFCO shocks and suspension components quickly earned a reputation for giving a racing team an advantage. Today, the AFCO advantage can be found in thousands of performance products.
    BUCKLE UP NOW, YA HEAR?
    • Anonymous24
      • Jan 2014
      • 253
      The panhard bar dictates rear roll center. If running a balanced setup, rarely should the panhard bar be adjusted in anyway.(RARELY!). Keep in mind each track has its own unique setup that is required. I have learned that if you must adjust the panhard bar, it should be equally adjusted on the pinion plate and chassis mount. Adjusting only one side WILL change rear roll center location. Rear roll center should be paired with the front roll center so the chassis rotates upon the same axis.
      Find me on Facebook: Impetus Dirt Racing Technologies
      • redracersmod
        • Jun 2013
        • 45
        So your saying put it at the recommended height and location and never touch it because it will be right? There is a reason its adjustable its to adjust it. What I'm asking is what affect does it have if you move the frame side up and leave pinion alone. Does it tighten the car does it loosen the car? Does it affect middle or entry or both? What happens if you just move pinion side up?
        • Anonymous24
          • Jan 2014
          • 253
          Yes I am saying once configured correctly, for that specific track, yes leave it alone. As I stated above, the panhard bar dictates rear roll center, and you want the front and rear roll centers paired. Its adjustable because each track requires a specific setup. Flat tracks require roll center placement more to the left than a high banked race track. Adjusting the panhard bar in the manner you are describing may help handling issues, but in reality, your setup may(probably) have a flaw in another area. Panhard bar should NOT be adjusted to correct handling issues.
          • Anonymous24
            • Jan 2014
            • 253
            Also recommended heights are all just educated GUESSES. Every car is different. Base set up sheets are for racers who haven't taken the time to learn vehicle dynamics. They are provided by chassis builders so the racer can be relatively fast without proper education and understanding of how every component works. Balanced setups are CRUCIAL. I have yet to come across a base setup that is truly balanced.
            • redracersmod
              • Jun 2013
              • 45
              Ok so then how do you adjust it to find the correct placement?
              • propit21
                • Jan 2011
                • 126
                would you not want to adjust from heat to main where the track drys out and more roll is needed in the car to help gain rr traction?
                • let-r-eat
                  • 2319
                  Why does NASCRAP make panhard bar adjustments throughout the night? They haven't dialed in their front and rear roll centers?I don't agree with Anonymous24. The front and rear roll centers and their placement is an important tuning tool.
                  • Anonymous24
                    • Jan 2014
                    • 253
                    No. As I stated above, the panhard configuration is setup specific per track that you are running. If you need more RR for the feature, you also need more RF. Its crucial to keep the setup balanced. I recommend adding ballast to the right side of the chassis for both the RF and RR in optimum locations to achieve more side bite. There are a few other adjustments that could be made, but adjusting the panhard bar isn't one of them. If you would like more detailed information, please PM me, and we can go from there.
                    • Anonymous24
                      • Jan 2014
                      • 253
                      QUOTE=let-r-eat;1807003]Why does NASCRAP make panhard bar adjustments throughout the night? They haven't dialed in their front and rear roll centers?I don't agree with Anonymous24. The front and rear roll centers and their placement is an important tuning tool.[/QUOTE]Its OK to disagree with me. I went to college to work NASCAR or NHRA. I have obtained the education those fellow racers have. Mechanical Engineering specializing in Vehicle Dynamics. I was unable to finish college due to having children. Full time work/full time school/racing every weekend 2-3 nights don't mix. I'm sharing knowledge that is accurate and track tested.
                        • 14320
                        I love this thread!
                          • 14320
                          Why is more roll needed to gain traction? Do you want more rr traction on exit?
                          • Anonymous24
                            • Jan 2014
                            • 253
                            Excellent question MasterSbilt_Racer. I look forward to the upcoming responses regarding your question.
                            • redracersmod
                              • Jun 2013
                              • 45
                              Actually from what I have read is body roll doesn't permote more traction on the RR tire. Correct me if I'm wrong.
