Setting motor in pierce car
  • TDR
    • Jan 2010
    • 85
    Putting together 06 pierce car and noticed there is a gap at the lf motor mount and engine appears to be running uphill.. I'm thinking the front end is bent.. Is this normal or is the front end twisted?
  • Lizardracing
    • 839
    My car doesn't line up either if sitting on jack stands squarely. The Chassis flexes a bit.
    • 1Blacksheep
      • Mar 2009
      • 701
      Its Bent ! Most of them are after 3 races .......
      • bob75
        • 2814
        wow , i got a car with 40 nights , and my motor goes in with no problems (not bent).
        • 99gill
          • Aug 2008
          • 12
          What motor are you running, if its a Ford motor then you have to cut the mounts down an inch. I called the chassis manufacture and they said i had to with my 04 pierce when i put my motor in.
          • Racer111
            • 796
            Make sure your bolt on mounts on the engine aint bent.Seen that many of times..
