quick change breather location
  • jsf74
    • 544
    Where is everyone hooking up there breather tube on the rear? I have mine connected to the case on the side where the gears go and think that might be where my leak is coming from.
  • JustAddDirt
    • 1893
    vent should be in the main case were ring and pinion is located. If you have it in the section were the 2 q/c gears are, that creates a lot of oil sling, might possibly blow it out. those 2 gears meshing together like they do almost make an oil pump.
    • jsf74
      • 544
      Thats the problem then thanks.
