pull bar hight on rear end.
  • racing_kid
    • Sep 2012
    • 127
    On the slick should the pull bar be mounted higher or lower? Base line called for middle hole on housing but wondered if moving it up or down would/could help with drive in the slick. i moved it to bottom on chassis and it helped some. Thanks
  • andy29
    • Sep 2012
    • 33
    12 1/2 " from axle centerline
      • 14303
      It is going to affect the stiffness of the pullbar. Either adjustment could be correct.
      • racing_kid
        • Sep 2012
        • 127
        Ok I think ill try moving it to the left first and if that dont help try going up or down. Also whats the advantage to moving the mount forward on the rear end?
        • washeduptoo
          • 1353
          As the rear end thrust it will increase the angle of the pull bar usually. Best of luck.
          • Towers21
            • Oct 2012
            • 63
            Moving it farther up gives the rear more leverage and it moves slower ie; takes longer to hook up but stays hooked up. Lower is just the opposite, hooks hard initially but goes away so then you are relying on LR bite off.
