Bms ride height
  • Deish98
    • Jan 2012
    • 238
    Bms ride height
    I'm running a 08 bms with under slung and I'm running in ump and I can't find ride heights to run with Hoosier tires so I was wondering if anyone who's ran a bms with Hoosiers tires got any information on where to to set ride heights
  • modcrewchief
    • Nov 2013
    • 17
    Call joel at close racing he will help u
    • racincowboy3
      • Nov 2013
      • 32
      We got the info from BMS with our 06 car for 6 inch on both fronts and 2 3/4 on the rr
      • Deish98
        • Jan 2012
        • 238
        That's what I got too I'm trying to figure out what they prefer for the LR
        • Deish98
          • Jan 2012
          • 238
          We run Hoosiers which set the car ride heights so we set the front at 7 on both sides and left the right rear 2 3/4 and we adjusted the left side to 3/4 taller then the right side and it was bout 25 left rear bite without driver and 47 left rear bite with driver... I was also wondering if anyone know how long the chain is suppose to be. Bms tells us 19 inches but 19 inches has way too much slack in it wear it can get caught on something
          • Deish98
            • Jan 2012
            • 238
            I wrapped it up with 3 layers of duct tape and it still has a lot of slack where it can touch the spring a little bit when it's not hiked
            • langdonracing48
              • Dec 2013
              • 183
              That's fine. It won't hurt anything
              • CHRISTINE
                • Sep 2008
                • 341
                Chain drop
                I run 18-1/4-18-1/2 in mine what will 19 do for the car?
                • drtrkr244
                  • 1024
                  Generally, looser on exit. The lr moves forward, increasing roll oversteer.
                  • CHRISTINE
                    • Sep 2008
                    • 341
                    Chain drop
                    With 18-1/4" my ltb is at 48* if i add another 3/4" to the drop should i drop the bar down a hole on frame to stay close to the 46* that everyone recomends or let it be around 52*?
                    • Anonymous24
                      • Jan 2014
                      • 253
                      Steering geometry and chassis roll are more about drivability. Steering geometry and chassis roll should be calculated first. Once configured, the moment centers and center of mass height needs to be designed around the geometry and roll. Remember weight transfer during cornering is not what we are looking for. The weight transfer we are looking to obtain is more front to rear for forward drive and corner entry. Obtaining that transfer is dependent upon center of mass movement on exit and entey
                      Find me on Facebook: Impetus Dirt Racing Technologies
                      • CHRISTINE
                        • Sep 2008
                        • 341
                        Chain drop
                        Thanks Jeff for speaking english to me lol. Hows that grt?
                        • Anonymous24
                          • Jan 2014
                          • 253
                          Hate to say it but I agree with stock car driver about watching the LR for frame contact. I have also come across BMS chassis's having some rear wheel hop
                          • CHRISTINE
                            • Sep 2008
                            • 341
                            Chain drop
                            I will do. Thanks My car is good now just searching if you know what i mean i got 4 feature wins and 10 heats i think just searching.
                            • Anonymous24
                              • Jan 2014
                              • 253
                              stock car driver you contacted me on facebook and I blocked you. i sent you pm asking for you to stop with the nonsense, but i guess some people never learn. as for a competitive car, you obviously have no idea who i am and who i work with.
