Quick change gasket?
  • missile07
    • Aug 2007
    • 680
    Been using the Winters quick change gaskets and they seem to come apart really easy and only last a couple nights....any info on the other brands? Which ones are better?
  • drtrkr244
    • 1024
    I learned this trick years ago. Silicone the gasket to the rearend, then use anti-seize between gasket and gear cover.That way the gasket stays glued to the rearend, and your gasket will last most of the year.
    • Anonymous24
      • Jan 2014
      • 253
      Be sure not to go too thick with the silicone. Doing so creates a gap between the gear and the bearing on the cover which can result in premature bearing failure.
      Find me on Facebook: Impetus Dirt Racing Technologies
      • drtrkr244
        • 1024
        Yep, a real thin coat is enough to hold gasket. I usually put it on with my finger.
        • Anonymous24
          • Jan 2014
          • 253
          I do the same as drtrkr244. Never have any problems.
          • JHobbs26
            • Aug 2007
            • 146
            I've always used the felpro 2303 gasket. Get multiple years out of it too.
            • Racer111
              • 796
              Make sure you get the right gasket there is a thick and thin gasket..
