poor forward drive off
  • modcrewchief
    • Nov 2013
    • 17
    Found that the lr tire is pulling off the ground on corner exit need help fixing
  • modcrewchief
    • Nov 2013
    • 17
    Any ideas how to fix this
    • JustAddDirt
      • 1893
      more RF spring
      more RF Shock compression
      more LR rebound
      How soft is RR spring?
      • modcrewchief
        • Nov 2013
        • 17
        200rr and 650rf on a chevelle clip
        • HuckleberryB4
          • 220
          More LR rebound
          • drtrkr244
            • 1024
            It sounds like your left rear front/rear shocks are the wrong length. Do you have extensions on them? Be sure to set drop of left rear according to your chassis mfgr specs.....good luck
            • modcrewchief
              • Nov 2013
              • 17
              The rear end has 19" drop per mfgr and has adjustable mounts
              • drtrkr244
                • 1024
                Heres what I would do then:
                1. With car at ride height, put ratchet strap on rr, and ratchet down RR to match travel of rr suspension.
                2. Put jack under seat area and jack up car until lr comes off the ground
                3. Look at all chassis components to see if anything is binding.
                It sounds like lr is running out of rebound travel.
                • Anonymous24
                  • Jan 2014
                  • 253
                  Chain limit the drop of the LR
                  Find me on Facebook: Impetus Dirt Racing Technologies
                  • modcrewchief
                    • Nov 2013
                    • 17
                    Yes the chain limits the drop
