Since IMCA, in their finite wisdom, has decided to allow quick changes next year, I have a question. Having never messed with quick changes, is there a gear change required? Meaning, if I'm running a 6.0, would I start with a 6.0?
9 inch to quick change
there a 40 point diffierences btw the two. so if u run 6.0 with a 9'' it will be 6.40 on the quickchange. thats what i was always told and what we go by
You'll be glad you switched ! No more leaks in the floor under each hub, under the pinion, and running down the inside of your wheels ! QC's are dry !Originally posted by Confused? View PostSince IMCA, in their finite wisdom, has decided to allow quick changes next year, I have a question. Having never messed with quick changes, is there a gear change required? Meaning, if I'm running a 6.0, would I start with a 6.0?
The 1st time you buy and/or change gears you'll never go back.
Measure your panhard bar height from the floor before you take the 9" out and match that height on the QC's pinion bracket. Don't compare it to the pinion, they're not in the same location.
Also, pay attention to the pinion center side to side. A 9" 60" wide "centered" rear end will take a 28.5" and a 32.5" axle while a 60" wide "centered" QC will take 2- 30.5" axles because the pinion is offset 2" to the right on a 9".
Also, make a note of how high your pullbar mount is above the axle centerline as well as how far front or behind the axle centerline. Make sure the upper brackets you buy for the QC are the same. There are many brands out there and most are different. Same goes for the damper shock mounting point.
Get these things right and you'll be close.
I'm sure someone you know locally with a LM would be glad to loan you a gear for a night till you decide what gear you need. I'd start out where you were or a little more and make your own decision.Last edited by mudeater18; 09-02-2014, 09:34 PM.
that's what guys around me told me when we went to a quickchange plus I call winters and they told me about same things that guys I race against told said jmo. its always best to call the people who make the products you buy and 15 hp isn't always how much you will loose 5-15 hp depending on what you have. but quickchange is best choice once you get you will stay with itLast edited by modracer18; 09-02-2014, 10:31 PM.
The difference isn't linear. A lower in number gear will require a slightly larger change than the higher in number gear. For instance, most running a 5.43 in a 9 inch may want a 5.65 in a quickchange. If you're using a 6.00 in the 9" you would likely go to a 6.1 in the quick change.Lower the number of the gear will require a larger numerical change.Originally posted by modracer18 View Postthat's what guys around me told me when we went to a quickchange plus I call winters and they told me about same things that guys I race against told said jmo. its always best to call the people who make the products you buy and 15 hp isn't always how much you will loose 5-15 hp depending on what you have. but quickchange is best choice once you get you will stay with itBUCKLE UP NOW, YA HEAR?
Thanks for the replies. Already knew about the pinion differences. And I build all of my brackets so that won't be an issue. Have a line on a q/c but will need to change the tubes. Won't know for sure for a week or two though. Unfortunately, late models are pretty much dead down here. Q/c gears are cheap enough and some of the info provided will get me going in the right direction.Bill W. and Dr. Bob......who could have known.
I recently made the switch and went from a 6.00 in the 9 to a 6.07 in the quick change and it pulls the same rpm in the tack.
The biggest problem i've seen is some of the quick changes have a 4:11 ring and pinion so this requires a 40 point adjustment,6.50 in a 9 inch 6.90 in a quick change with a 4.11 ring and pinion,now if you have a 4.86 ring and pinion in your quick change the gear that you are running in your 9 inch should be real close so I would start with the 6.0.Originally posted by Confused? View PostSince IMCA, in their finite wisdom, has decided to allow quick changes next year, I have a question. Having never messed with quick changes, is there a gear change required? Meaning, if I'm running a 6.0, would I start with a 6.0?
Hope that helps.
