Need help in slick
  • Dirt racer 10
    • Jun 2012
    • 14
    Need help in slick
    Car is an imca northern sport mod. Solid 3 link. Car is very good when there is grip in the track. Car is too loose on entry and into the center of the turn when off throttle when the track slicks off. Seem to wait forever for the rr to take hold so I can get back on throttle and can't go into the corner hard enough to get position on anyone. Corner exit is good. Just looking for more ideas on what to try. Thanks in advance I love reading the forum.
    Springs: lf 550 rf 600 lr200 rr175
    Left 54% rear 57% bite 130 lbs
    Pan hard is 3inches above to 3 below rear end centerline which is about 18 degrees
    Lr bar 21 degrees rr bar is 0 degrees
  • Duckhnter83
    • Apr 2013
    • 152
    What tire pressures? They are important when your on slick. Also increase the angle in your panhard bar helps induce some side bite. And around here we run with no more than 52% left on the slick. Also going up to a 200lb or spring on the slick will help your entry.
    • Confused?
      • Apr 2009
      • 418
      And to add, if you can, try to stay in the throttle a little. Meaning, do t get completely out of the gas on entry. It makes a huge difference.
      • dirt0
        • Oct 2012
        • 237
        How much left with a 120 lb. Driver
        • drtrkr244
          • Dec 2007
          • 1024
          Stiffen lf spring to 600/650
          Siffen rr spring to 200
          Raise jbar on frame or lower on pinion
          Soften compression rr shock
          I think your left side % is ok.
          • Dirt racer 10
            • Jun 2012
            • 14
            Tires pressures last time out: lf 12 rf14 lr10 rr13
            If i shorten the panhard and add angle will that plant the rr sooner?
