tire questions
  • fastford02
    • 153
    tire questions
    What does it mean after a 40 lap race with new tires (a-40) hard, the tires are very hot but not worn at all. In fact you can still see where the tits where?
  • Anonymous24
    • Jan 2014
    • 253
    I would have to say tire spin. Tire spin causes the surface layer of rubber to heat very quickly while the interior rubber remains cooler. If the surface area heats to high temp and then cools rapidly, the rubber will harden up similar to the skin on your feet when it calluses up.
    Find me on Facebook: Impetus Dirt Racing Technologies
    • 72Dubya
      • Sep 2011
      • 504
      The tire wasn't hooking up. If it was your LR I would assume the RR was not as hot but showed wear.
      #72W U.M.P Stock Car
      • fastford02
        • 153
        Actually it was both rear tires. Both were hot but no wear what so ever
        • Bcollins82
          • Jul 2009
          • 322
          I'm guessing they were also shiny or polished looking?
          • fastford02
            • 153
            Somewhat but not too bad. Looks like if it were tire spin they would be feathered or worn some?
            • drtrkr244
              • Dec 2007
              • 1024
              Did the car get any better once the tires got some heat in them? If not, I would keep adding rear weight till it stopped. That's a pretty hard tire and could use a lot of grooving and siping if allowed.
