Help On a Metric Front stub a mod
  • ddsprint
    • Aug 2008
    • 45
    Just looking for some set up info on this type of Car, I have done a advanced search on here an found nothing, Any direction pointing would be greatly appreciated, thanks
  • Bcollins82
    • Jul 2009
    • 322
    You'll need to post a lot more info to get any kind of decent answer. What kind of chassis? What lower control arms? What style of rear suspension? What tire? Posting your current setup and type of problems you are having will also help.
    • ddsprint
      • Aug 2008
      • 45
      Ok, I'm waiting for the info on some of those questions you have, when I get the answers I will post info, thank you,
      • ddsprint
        • Aug 2008
        • 45
        Spindles are gm metric, lower a frames are off a nova. Upper a frames are Rightfoot performance. Chassis really isn't a really a copy of anything. Front end geometry is close to a bob pierce car. Rear end geometry and cage was original, not a copy
        It is a metric front stub
        lf 650 spring
        rf 700 spring
        lr an rr 175 springs
        1/4 toe out
        9 degree pinoin angle
        1/4 lead on rr
        these are the ride height
        lf 7 1/4
        rf 7 7/8
        lr 7 3/4
        rr8 3/16
        Back spacing is 2" all around, No extra money right now for a 3" offset on rr
        I realize at this point upon reading they are wrong, but it is where I put it, Unfortunately I don't have a guide so to speak,
        tires G 60 Hoosier's
        weight
        lf 492
        rf 513
        lr657
        rr 584
        total 2246
        left 1149 51.2%
        rear 1249 55.3%
        cross 1170 52.1%
        right 1096 48.3%
        Scaling was done with lr axle out and no driver, driver 215 ibs
        The car does not want to seem to turn corner entry seems fine
        mid corner and off big push throttle the rearend to turn,
        I also realize this was not the best route to go, I thought there was more info to work with than there was, so it becomes mor challenging,
        I'm mainly looking to create a baseline,
        So whatever some one can make of this, or guidance on the situation to give, thank you,
        • Dirtracer50
          • 140
          I would try trailing the RR a quarter inch to start with and see if that helps your push. Also the rear springs sound a little soft to me.
          • jasjenh
            • Dec 2011
            • 61
            x2 on the rr. start straight up or a 1/4 inch back. on all our metric clip cars with nova lowers whether it is a b-mod or a-mod we start with a 600 rf and a 550 lf. but that really depends on your shock package now a days.
            • drtrkr244
              • 1024
              We ran a pair of 600's in our Pierce car. Also, only ran 60lbs of bite with driver. I would square up RR also.
              • mod88s
                • 226
                Raise the left side % to help the car turn. try and raise it 1% to 52.2 and start there.
                • bob75
                  • 2814
                  really need to know what kind of chassis if its a pierce call me 815 541 9656 numbers are not good if a pierce.
                  • mudeater18
                    • 1599
                    My 1st two thoughts as well.
                    • Renegade Cust Susp
                      • 349
                      70# of lr bite w/o driver may be a little much. Could be causing your throttle push.
                      Broc Burton
                      go.fast.crs@gmail.com
                      • ddsprint
                        • Aug 2008
                        • 45
                        thanks for the feedback, Bob unfortunately it is not a pierce, apparently home built, with pierce geometry in front or close to, that is what I was told, otherwise I would call, it is somewhat a oddball
                        • 1fast1
                          • Oct 2009
                          • 50
                          where are you located ?
