Pinto spindles
  • dove14
    • Nov 2010
    • 20
    Pinto spindles
    What the difference or advantage to running the 2 inch drop pinto spindles versus the standard pinto spindles?
  • BMOD6
    • Jan 2009
    • 204
    drop spindle
    I dont believe there is an advantage on the dirt for them. On the pavement there would be an advantage expecially on a metric frame where frame height is a problem. You wouldnt have to run an extended pin lower ball joint to get the roll center where you want it.
    • zachmckenzieracing
      • Dec 2010
      • 36
      spindle homework
      as i am starting to find out, many people dont understand the geometry of a vehicle. i have done alot of research on parts, and found that there is a very important part of a spindle that no one talks about. im not going to give my knowledge away, but i will say this: DO YOUR HOMEWORK!
      • proped
        • Mar 2011
        • 4
        Hey Zach what kind of king pin inclination do you run in your spindles.
