Anyone had any issues running the lines on lower frame rail vs upper? Feed and return? Thanks
KSE Pump and lines
I always run my fuel line (feed line)on the lower rail return on the upper side easy to keep track of and always have some fuel in the feed line the power steering side in most cases wouldn't matter. but you should be ok just stay away from the heat of the heat as much as possible.
Position the fuel lines in an area that is not in harms way in case of severe crashes. Other than that, I prefer the lines to be mounted higher on the chassis rather than lower. I always try to keep all component weight high up, and located on the chassis in an area that is beneficial to performance. You may say what does fuel lines have to do with handling. Well every component has weight, maybe 2 pounds, maybe 3O pounds. The mounting locations of such items have a profound affect on weight, and the transfer of weight dynamically.Find me on Facebook: Impetus Dirt Racing Technologies
I'm wondering if it matters higher or lower for start up too. I've seen some higher and some lower. Just want a real reason why they differ.
I have mounted the lines in several locations. As long as the pump stays primed, you shouldnt have any problems. I strongly recommend running a fuel pressure gauge when running that type of pump. A failure in an internal seal can allow fuel to bleed into the power steering system or vise versa. Running a pressure gauge can be a sure indicator of a malfunction in most circumstances. This is a lesson that was learned the expensive way if you get what I meanFind me on Facebook: Impetus Dirt Racing Technologies
I have a fuel pressure gauge. Does it stay primed better top or bottom? Also one of our cars has a lever just below headers to turn fuel on and off. Why?
the lever to turn the fuel on and off is helpful when you have to remove your pump for service or repair. having the fuel shut off stops the fuel from draining completely from the inlet line when disconnected from the pump, saving fuel and making the priming process a little easier. as for keeping the pump primed, i have had no issues with priming no matter the location of the lines. i also must say that i have always tried to keep the lines straight as possible with minimal curves or angles.Find me on Facebook: Impetus Dirt Racing Technologies
So when running a shut off valve should I turn valve off and let it run outta fuel while running or what? I'm running 110 also.
no. while engine is off, shut the valve then remove the inlet line. you will lose some fuel from both inlet and return. we also shut the valve while transporting the car. the shut off valve is more convenience than necessity.Find me on Facebook: Impetus Dirt Racing Technologies
So the guy that told me to shut off valve and run dry was full of it? I'm just trying to figure out the best thing to do. Fuel and carb wise.
The engine builder that we use says that a shut off valve is not needed. Running the fuel out is hard on plugs. Currently we do not have a shut off valve and havent had any carb or fuel issues.Find me on Facebook: Impetus Dirt Racing Technologies
The shut off restricts the fuel flow when performing maintenance/repairing the pump. Once the fuel feed is removed from the pump, fuel will flow through the feed line.Find me on Facebook: Impetus Dirt Racing Technologies
