Wanting to know if anyone has any luck running a direct drive powerglide on with a 4 bar car. Without breaking tailshaft or case??
Direct drive powerglide
I used to run powerglides in the late 90's and early 2000's. The cars didn't lift up like they do now. I never cracked one due to normal racing. Actually got a couple seasons out of one. I ran a support brace from the rear of the engine to the trans mount, though. You cannot mount the trans mount to the chassis at the tailshaft mount. You will crack it then. As long as you don't bottom the driveshaft out, I don't see why it wouldn't work. I would definitely build a brace, though.
Save your money and buy a good trans (Bert, Brinn or Falcon) them splattermatics will hurt you.I have been got by one and have seen many others.They were made for 6 cyl putt putt cars.I know that drag racers run them (with different cases) but they arent decellerating and jumping ruts and cushions.They used to be better than the 3 speeds with a clutch that we used to have to run, but now we have racing transmissions that are probably the cheapest things we can put in our cars.A powerglide given to you will cost a fortune if you tear the X out of the bottom of the car and break or cut your leg.
I did the powerglide with a torque tube cus I had some glides ready..Trust me save your money on get a bert,brinn,falcon..these transmissions are WAY more reliable but you will also pick up some hp.. The difference I could feel was about like in our old stockcars going from a stock heavy torque converter to a glide with a torque tube..
Called Bushore
Called Bushore transmissions today and asked about running one of their transmissions with a 4 bar car. I perfectly understand what I need to check and have done in order to do that. What I didn't understand is that when he found out it had 1.82 written on the top of the tranny with a black marker it was unusable in a mod. Wasn't able to get a full explanation as to why. Does anyone know? I thought I heard him to say that it was run in low only? The guy that has the tranny says he ran a 3.50 gear or something like that in a chevy 10 bolt rear. He claims I can run it but would have to figure out the gear ratio since I was running a 9" ford rear. Any help by people with experience with Bushore trannny's woud be appreciated. Was thinking of running this in a sportmod instead of a 4 bar car. Thanks
I called Bushore again today, I must have missed it in the conversation but that was what he said, can only run in low gear. My bad, I will say one thing, they sure don't mind taking the time to talk to a racer. Very impressed with the customer service there and having ran a Bushore in a different type car years ago, I can say they have good products as well.
I run a powerglide and have now for 7 years I just put a mount on the chisis wher the mount is on the tranny.. And it is a 2 speed powerglide & never had any trouble....
Your lucky frontrunner, but your luck may eventually run out.Take it from somebody with alot of power glide experience in modified and latemodels. I was hard headed and thought I could get by with one also, until it ripped the bottom of my car out, bent my seat and bruised my leg(lucky it wasnt worse)
Them things are like sittin on a powder keg.
i had 8 powerglides break parts internally in one season....i will never have a trans that works off fluid pressure in a racecar....ever!Bartley Grant
#1 red,white and blue sportsman and mod-#24 lightning/smokehouse grill mod
www.bartleygrant.com
I have never had any problems & hope I never do I just go and find old cases & buy all the racing parts & we put them together rselfs And I run the shut off valve to the (not a nice word)(not a nice word)(not a nice word)(not a nice word)pit so I can control it but this will b the 8th year on my powerglide & every 2 years I put new clutches & the bushings in it...But I do run a rubber mount from it to the chasis... But if it ever breaks I have three more on hand......
