Whats the advantages of switching? Handling better? Like to hear some thoughts thanks
stock metric lowers. to nova. lowers
wider track width
longer a-arm
lengthens wheelbase for more rear %
have to drop spring rates a good bit.
motion ratio for metric is 25%
motion ratio for nova a-arm is 30%I think there should be lifeguards in the genepool.
myself I liked the pinto spindle on the nova a-arm.
quicker steering
much tougher than metric spindles.Last edited by JustAddDirt; 10-08-2014, 09:18 AM.I think there should be lifeguards in the genepool.
what measurements are you looking for. I have some lying around I could measure for you. We like the pinto spindles too. It was a big difference when we switched from metric lowers to nova. One other thing is you get more wheel travel because the nova is shaped like a banana. Only gripe I had when we switched was tie rod clearance, because of the arm on the spindle is higher, but with the new bent tie rods it is a non issue.
