Difference between A & H
  • thinkstomuch
    • Sep 2013
    • 231
    What are the differences between Hoosier A & H compound tires? I've got a new H through a buy out and haven't used it because I don't understand it.
  • langdonracing48
    • Dec 2013
    • 183
    an A is a medium compound, H is hard. very hard. good for really dry slick track.
    • jsf74
      • 544
      h sucks!!!!
      • bittight
        • Jun 2009
        • 358
        H is very good tire if you know when to use it and how to cut it, not the best tire in the rubber but in the dust, or even hard packed ripples it's hard to beat. They don't last long if your cars hooked up about 50 laps it's done
        • Lizardracing
          • Sep 2009
          • 839
          Anyone know anything about UMP's new tire? The A40s?
          • big.ed
            • 501
            its suppose to be the same rubber compound as the LM30
            • langdonracing48
              • Dec 2013
              • 183
              The A40s is the same compound as the lm30s they started running last year. I liked the original lm30, I know nothing about the lm30s.
              • JustAddDirt
                • 1893
                LM30 from what I remember of them, they are garbage. They glaze over under cautions, or never take off at all.
                I think they have a lot of synthetic rubber in them. They feel plastic-ey
                I know of no one that run an LM30 in my area, they would typically go from an LM20 straight to a LM40.
                • save the racers
                  • May 2013
                  • 271
                  I know of no one that run an LM30i in my area, they would typically go from an LM20 straight to a LM40.
                  I think they changed the compound around the time Mars won the firecracker and bloomquist protested his tires. Bloomer just knew Jimmy was cheating tires because after a caution he just took off again, tires were legal they had just changed the compound. I think that was about 3 years ago.
                  • JustAddDirt
                    • 1893
                    tires
                    We can only hope they changed it
