Right now I'm working on putting a Kraft kar back together and I got a couple of questions. The car did not come with a center section for the 9 in so the j-bar was not bolted up. The rear end is tilted way back and I can not figure out how to loosen the pull bar ( spring pullbar) to get the j bar back on it. It's a 4 bar car if that helps.Question #2 I have a bert ball spline in it and the yoke will not slide out is the normal or should it slide out easy?
Reassembly questions
