I have a brinn transmission and a Bert reverse mount bell housing and starter. Can I use any flywheel for it or does it have to be the Bert to match the bell housing and starter?
Bert/Brinn flywheel
It needs to be a Bert Flywheel.The flywheel needs to match the Bellhousing.Make sure you use the correct flywheel too...for either an external balanced or internal balanced engine.Originally posted by emodracer View PostI have a brinn transmission and a Bert reverse mount bell housing and starter. Can I use any flywheel for it or does it have to be the Bert to match the bell housing and starter?
Don't forget there is a bellhousing bolt behind the starter.Many forget that bolt,it will help keep the bellhousing from cracking near the starter.Last edited by runyou-2; 12-06-2014, 12:10 AM.
